Create New Interface Settings
The following table provides interface properties for the settings in the Create New Interface window.
Table 1. Interface Properties
Field Description
Name Name of the interface.
Mode Describes how traffic is forwarded on the interface topology. Options are:
  • Physical - The topology is the native topology of a data plane and it represents the actual Ethernet ports.
  • Management - The native topology of the Universal Compute Appliance management port.
VLAN ID ID for the virtual network.
Tagged Indicates if the interface tags traffic. When traffic is tagged, the VLAN ID is inserted into the packet header to identify which VLAN the packet belongs to. Tagging can identify the port or interface to send a broadcast message to.
Port Physical port on the Universal Compute Platform for the interface.
Management Traffic Enable or disable Management Traffic through this interface. Enabling management provides access to SNMP (v1/v2c, v3), SSH, and HTTPs management interfaces.
MTU Maximum Transmission Unit (MTU). Standard is 1500 bytes. Fixed value.
Layer 3
IP Address For an Admin topology, the Layer 3 check box is selected automatically. The IP address is mandatory for a Physical topology. This allows for IP Interface and subnet configuration together with other networking services.
CIDR CIDR field is used along with IP address field to find the IP address range.
FQDN Fully-Qualified Domain Name
VRRP Supports load balancing and high-availability functions for the Universal Compute Platform cluster.
IP Addresses
Record the IP address relationship between the cluster‘s direct interfaces, VRRP, and external access.
Priority
VRRP uses priority settings as a mechanism to arbitrate mastery of the state of exchanges across members of the cluster.
Router ID
Allows segmentation of a routing domain.
Note: In a stand-alone configuration, configure priority and router ID with a numeric value. However, in a stand-alone configuration, the specific value is not important. These attribute definitions are important in a multiple-node configuration.
